Ok, Here it goes.
Shortly after I got my 2005 cummins 2500. I started getting a rough Idle and on acceleration when I let off the rpms hangs and kind of bounces on the way back down and I have a couple dead spots in acceleration also. The truck had a EDGE EZ installed when I got it, first thing I did was unplug it when the problem started. So far, I have replaced the throttle position sensor/APPS, fuel rail pressure sensor, fuel rail relief valve, cam/crank sensor, fuel actuator on the CP3, added a air dog to replace my stock fuel pump, had my ECU reflashed, when Dodge reflashed it they did some trouble shooting and said my #4 injector is bad, I replaced that. Diagnosed my CP3 and it works fine. I took it to who is supposed to be the diesel guru in my area and he says he don't know, because it isn't throwing codes.
I was told It could be numerous injectors, just the #4 was the worst. I have 6 new injectors I am going to put in next weekend. I am worried that this won't fix it either. I am running out of money to throw at it. If anybody else has experienced anything like this, please let me know.
