I figure out of all the Dodge boys here, I can't be the only one with a 99 Sebring convertible. I've got a problem I'm trying to fix and I need some help. Here goes:
The problem is with the blower motor resistor pack... it doesn't work. I get blower motor only when the switch is set to high. Now I've put a new genuine Mopar resistor pack in it's place, and all switch settings worked for about 30 seconds... now we're back to high speed only. The thing that is confusing me is that there is a zener diode in this resistor pack... and it is the component that is failing. I know this for two reasons... 1) I checked the zener with a Fluke and found it to be open, and 2) I jumpered across the diode with a straight wire and get all speeds functioning properly.
Now the questions:
1) what keeps causing the zener to blow?
2) why the he!! is there a zener on a mechanical motor speed controller?
The only thing I can figure as to WHY the zener is even there, is if the LTD version of the car has some kind of automagic climate control... this JXi model does not... simple rotary, mechanical knobs.
Even if the zener doesn't need to be there in my application, why does it now all of a sudden start blowing them?
I'm so confused
Thanks,
Jim
Now the questions:
I'm so confused
Thanks,
Jim
