Need help with codes
AFE/AEM prices
FASS or WALBRO?
I just installed the Juice with Attitude and need some help figuring out the codes it is throwing. I show P0113, P0069, and P0237. I must admit I forgot to fully connect the MAP sensor as the instructions were a little vague on this one. However after contacting edge tech help all is running fine but need to know how serious the codes are and what will it take to clear them? Any help would be greatly appreciated. For sure don't want to go to dealer to have them checked out.
Truck is a 2005, 3500 slt, srw, and automatic
Had the same thing happen to mine tonight after I installed my Juice with Attitude. Did you ever figure anything out on yours?
Can't read/reset codes with your Edge?
Mike
P0113 Intake Air / Charge Temperature Sensor High
P0237 Turbocharger Boost Pressure Sensor Low
Don't know about the other one... Eric
P0069 Generic MAP - Barometric Pressure Correlation
These were set because the MAP sensor was not reading correctly. They will go away on there own after a lot of start/run sequences. MIL/CEL should go off after about 4 start/run sequences.
As long as the MIL/CEL light does not come back on there is nothing to worry about. Any ODBII scanner should be able to clear them on your 05.
