2nd Gen Non-Engine/Transmission Need help with decision
Engine/Transmission (1998.5 - 2002) So, Whats an APPS?
2nd Gen Non-Engine/Transmission BD x-monitor
I am looking to order my guages and mounts but have run into a snag. Who to buy from? :confused: So this is what I have narrowed it down to:
TST Proformance: Di-Pricol Boost, Pryo, and Transmission, Full 3 A-Piller with speaker hole and their KDP kit. Total price around $360.
Wildcat diesel: Isspro Boost, Pryo, and Transmission, Rod's Pod. Total price: $289
I am wondering if anyone has purchased from either of these two companies and can tell me which on is better. I know opinions will differ. I would purchase the guages from Geno's but on some of the guages the customer must supply the wiring and I really was looking for a complete kit that has everything I need to install the guages.
I am also going to purchase a B&M plug so I can install the transmission guage.
Also which is better the A-piller or the dash mount? I am undecided. Both look great but really don't know which on to go with. Any ideas, thoughts, etc?
One other thing after I purchase the Mag-Hytec front and rear differential pans and transmission covers I plan on installing guages to monitor the differential temps, engine oil and possibly fuel pressure. This will mean both the A-piller or dash mounts will be used. After everything is said and done I believe I will have close to 7 guages installed and running.
thanks
Dawna
Take a look at the Westach Duel Gauges. I have the triple a piller and have the duel EGT-Boost, Fuel pressure(single) and duel temp. Iput a small toggle switch in the a piller and can monitor the differential, trans and oil temp with this set up. I like it maybe you will too. Good Luck:)
