Need help with Jordan 2020
Which Batteries for fivers
Carlisle brake controller
I will be installing my Jordan Ultima 2020 this weekend. After reading the instructions, it says to run the wires directly to the battery with an auto reset circuit breaker in the positive wire. My truck has the trailer wiring connection under the dash. Can I just use the pig-tail that came with it and plug into the existing wires or is it necessary to run the wires directly to the battery?
Thanks in advance,
Jordan's instructions say if white ground wire is not connected directly to neg battery post, operation may be erratic. Don't know about the positive side. I connected both directly to the battery as per the instruction sheet.
