Engine/Transmission (1994 - 1998) Need New NVG4500 transmission
Engine/Transmission (1994 - 1998) 3 gallons of unleaded in my diesel
Engine/Transmission (1994 - 1998) Broke it again
The 5-speed transmission in my 1998 work truck (3500 cab/chassis 4. 10 gear 2 wheel drive) took a dump today. It will not pull in any gear and has a grinding noise that does not increase with different gear selections. It will still shift into any gear easily, but will not pull at all. Seems like an input shaft or main shaft problem by what I can tell.
I am looking to (quickly) buy a complete replacement transmission. I will need the quickest, most reliable way of doing this. The truck is in my shop right now and the transmission will be removed tomorrow (friday the 28th). The truck has 130,000 miles on it and has a nearly new SouthBend CON OFE clutch (installed @ approx. 110,000 miles). Who do any of yall recommend for a NEW transmission? I want NEW, because I want reliable... I depend on this truck daily to make my living and have never had good luck buying someone elses troubles with "rebuilt" crap. I have heard of a "Bloominthol" or something like that, but don't know the spelling so I could not get any search results. Thanks for any advice!
John
btw, I am not sure if they will interchange, but if I had a choice, I would prefer the earlier style 4500 (like my 1996) because I like the shift throw and feel better... I reckon right now a begger can't be too choosie though!
Clutch
Just removed the transmission and the center hub of the clutch is broken loose. Gonna order the GOOD clutch from SouthBend (13" CON OFE). Thanks for all the input. When this cheesie transmission does croak, at least I'll know where to get one!
