Need Replacement Trailer Harness Wiring
Replacement Seatbelt Install ?
Should I buy it?
The trailer harness wiring at my bumper has many problems. I would like to:
-Find a plug in replacement from the wire harness to the bumper
-Find a plug in add on to add on a second plug to a fifth wheel plug in the bed. Note: I'm not actually going to use the 5th wheel, but I would like the wiring to add some additional tail lights and back up lights that are going on top of my rack.
Google searches come up wit ha lot of parts, some that say plug and play, but the reviews say something different. Any suggestions would be great. Thanks
as far as the extension or should say additional plug into the bed I used this
https://www.etrailer.com/Custom-Fit...IVyrzACh1MEw9XEAQYASABEgJWTPD_BwE#ymm/2/years
on my 2017 truck it was plug and play outside of drilling a hole in the side of the bed for the plug to fit into, has worked great so far. Disconnect the harness from the plug behind the bumper, attach the two plugs on the extension to the correct ends of the oem and drill your hole, mount and done. Don't know if it will work on your year but sure did on my 17
