need smog testing help
G56 Oil Quantity
SF CA bay area smog referral needed
I've posted in 24v, but need help/knowledge/info!!!
TDR members... . I sent my truck over to a TDR member recommended testing station in the SF east bay (Fremont). They would not test my truck because it didn't have a catalytic converter. I am absolutely certain that a 98. 5 24v truck didn't come with one, but it did come with a 'resonator. ' The tech said that every book/reference he checked said that it needed a cat and would not test it.
Can anyone help me out with a reference? I'm going to call a dealer (no local dealer anymore... most of them closed by the Obama takeover!).
thanks in advance.
This issue keeps popping up. Try to find a 98. 5 cat in the parts manual. It ain't there. 12V, yes... 24V, nope.
ITEM PART
NUMBER QTY LINE SERIES BODY ENGINE TRANS TRIM DESCRIPTION​
Exhaust System EXHAUST SYSTEM​
Note:
EMM = Magnum 5. 9L SMPI V8 Engine
ETB = 5. 9L In-Line 6 Cummins Turbo Diesel Engine
ETC = 5. 9L Cummins 24V Diesel Engine
ET0 = All 5. 9L Turbo Diesel Engines
1 06100940 2 2, 3, 7, 8 62, 63, 64,
65
ET0 BOLT, Hex Flange Head,
M10x1. 5x50
2 52018191 1 ETB CONVERTER, Catalytic
-3 52103042AB 1 2, 3, 7, 8 62, 63, 64,
65
ETC RESONATOR, Exhaust
4 PIPE, Exhaust
52019171 1 3, 8 63 ET0
52019172 1 3, 8 64 ET0
5 52018532 1 ET0 CLAMP, Exhaust
6 52018666 1 2, 3, 7, 8 62, 63, 64,
65
ET0 BRACKET, Catalytic Converter
7 52018668 1 2, 3, 7, 8 62, 63, 64,
65
ET0 HANGER, Exhaust
8 52017607 2 INSULATOR, Exhaust
E0036369 Mopar V-Line Alternative Part
9 06100584 2 BOLT AND CONED WASHER,
Hex Head, M8x30x20
10 MUFFLER, Exhaust
52019324AB 1 2, 3, 7, 8 62, 63, 64,
65
ETC
E0019372UF Dynomax Cat Back Single
Exhaust
E0019377UF Dynomax Complete Exhaust
E0021443 Mopar V-Line Alternative Part
65
ETB
Exhaust
E0019377UF Dynomax Complete Exhaust​
RAM PICKUP, RAM CAB AND CHASSIS (BR)​
SERIES LINE BODY ENGINE TRANSMISSION
E = WS RAM
1500
L = RAM 1500,
2500, 3500
3 = HD DODGE 2WD
8 = HD DODGE 4WD
1 = Lt. Duty DODGE 2WD
6 = Lt. Duty DODGE 4WD
2 = Med. Duty DODGE 2WD
7 = Med. Duty DODGE 4WD
61 = REG CAB 6. 5 FT BOX
62 = REG CAB 8 FT BOX
63 = REG CAB CHASSIS
WHEEL BASE 1
64 = REG CAB CHASSIS
WHEEL BASE 2
65 = REG CAB CHASSIS
WHEEL BASE 3
EHC = "Magnum" 3. 9L SMPI
V6 Engine
ELF = 5. 2L V8 MPI Engine
EML = 5. 9L V8 MPI Engine
EMM = 5. 9L SMPI V8 Engine
ETB = 5. 9L I6 Cummins Turbo
Diesel Engine
ETC = ENGINE- 5. 9L
CUMMINS 24V DIESEL
EWA = 8. 0L V10 MPI Engine
EMO = ALL 5. 9L 8 CYL
ENGINES - GAS
ELO = ALL 5. 2L 8 CYL
ENGINES - GAS
ET0 = ENGINES - ALL 5. 9L
TURBO DIESELS
DDC = 5-Speed HD Manual
Transmission
DDP = 5-Speed Manual Transmission
DDX = 5-Speed HD Manual
Transmission
DEE = 6-Speed HD Manual
Transmission
DGK = 4-Spd. Automatic 42RE
Transmission
DGP = TRANSMISSION - 4-SPD.
AUTOMATIC,47RE
DGT = 4-Spd. Automatic 46RE
Transmission
DD0 = ALL 5 SPEED MANUAL
TRANSMISSIONS
DG0 = ALL AUTOMATIC​
TRANSMISSIONS
