OK, let the discussions begin.
I am having trouble with my automatic transmission on my 1998 24 valve 4X4. It is a Quad Cab, Short bed. I pull a 22 foot boat (boat and trailer are under 6000 lbs) at least once a year to Lake Powell from Denver. Before the transmission problem was noticed I got 14. 8 per gallon round trip pulling the boat. I also got 20 running empty on the highway and around town I was getting about 15 to the gallon. This spring my dealer found a trans problem (I noticed it was not shifting correctly) even though it was still getting the 15 per gallon average. So first one of the solenoids was replaced and it still failed to lock up the torque converter. Then they replaced the torque converted and clutch plates and it was deemed “fixed” they also flashed the computer. Since then is lugs down when driving in any gear, towing or not, in town, on the road, etc. I did change to 285 tires about two weeks after the work was completed, it worked or should I say not worked as described. With the new tires on I took my boat to Lake Murray in Oklahoma and got an unbelievable 9. 4 to the gallon round trip. Also unloaded in town I am getting 10. 1 and on the highway unloaded I get 16. 3. The dealer says it is the tires and there is nothing they will do. I have extended Dodge warranty, so I would prefer to get it fixed through them. I have not done a Banks setup or anything else to it yet, but want to. And Banks (as do the others) say to get the trans figured out first.
Now what advice can any of you offer?
Thanks,
Dave Gross
Thanks,
Dave Gross
