I cleared the codes on friday (1693, 0234, 0253) I made sure I had delectric grease on all connections. I think I have a good connection on my Blue chip pump cover. No Injectors, just Drag comp. comp grounded to the intake horn.
So I hooked on to my 5th wheeler (7k lbs) put Drag Comp on setting 3 pulled it about 200 miles No check engine light, but I ended up with Codes 1693, and 0234. (over boost code) the truck stumbles or chugs under a load pulling hills on Friday still with lots of power. Sunday I thought well I'll disconnected the pump wire and tape it up so it didn't touch anything and the truck still chugs. Unhooked the 5er and with the pump wire STILL disconnected running down the highway the truck still had a little chug to it. you can tell there's something wrong, but I only have these codes.
is my Injector pump going out? I have a new Lift pump and filter about a month ago.
thanks in advance
thanks in advance
