Need some help identifying a turbo & exhaust housing off a 4BT
6bt mated to a thm400 gm???
Barring / Rotate Crankshaft
I just scored a turbo off a high mount Ford application 4BT... It is a Holset but looks a little small to be a 1990 era H1C. . Also, it is a reman Cummins so it has been replaced (and as a result it is very tight). . What I am really trying to do is figure out which exhaust housing it is. I was under the impression that all 4BTs had 12cm2 housings, but this looks larger, so I am thinking maybe its an 18??
On the housing, numbers are:
300 on one side
Then on the other:
5519410
18 128
I am assuming because there is an 18 there that's what it is?
On the 16's and 12's I've seen, in a random clearly seperated elsewhere on the housing but this doesn't have it...
On the turbo, the numbers are:
Kit: 3802107
Assmbly: 3522068
Serial: 345897
Thanks!
Have you used a wire brush and brake clean on the inside of the housing? I have a 12 that says 16 clearly on the outside of the housing, but on the inside near the mounting flange it says 12. I would bet it's a 16. Can't help with the turbo though.
Cool I will check, never knew that. .
