I've got a '93 Dodge (of course
) B250 van. It's got the 4spd O/D automatic (of course
). It leaks. I was underneath it, for an oil and filter change, and located said leak.
It's not from the bell housing, up front (Thank God!) and neither is it from the rear seal around the output shaft (TGx2).
The leaky spot is on the right-hand (driver's) side of the housing, nearly at the rear end of the transmission, back there where it's real narrow, and about 4" forward of the exit point of the driveshaft/yoke.
What's the proper name of that gasket, and how much of a P. I. T. A. is it to change?
Next question: Leaking due to age, and lack of sufficient driving to keep it swelled and sealed, or does that gasket blow and fail due to something inside the housing getting damaged, somehow?
I suspect (not worth much, for the record) that it's the engage/disengage doohickey for the overdrive unit, being so far back.
transmission works beautiful, and shifts are smooth and sure, just like new (doesn't have 70,000miles on it yet)
You first-generation guys may have the same transmission as what's in my van. (Actually, it may also be nearly the same as what's in my truck??)
