CB Noise
#1 power direct from the battery, run a seperate ground as well, coax does work well for this especialy with a gasser and spark ignition.
#2 if you are using a remote speaker, try unplugging it and see if the noise goes away, the speaker cable can sometimes back feed noise into the radio amplifier section.
#3 if your SWR is below 2-3 you should not have an antenna ground problem, if it's above 3 you either have a bad ground or no antenna.
#4 you can add an alternator filter, it's just a large capacitor that you connect to the alternator output. Should be available from just about car audio store.
#5 best to turn off your cb radio before starting the engine.
#6 check any small motors that may be running when the engine is running, like the heater fan etc.
Neil
9SF915
