Gravel uphill is the only problem I’ve encountered as I wouldn’t DREAM of driving this truck in snow or ice. It appears manual or air locking rear may be a solution.
4WD or 2WD:
500# is a minimum. That’s “empty”. Up to 1k doesn’t much affect my fuel mileage, but it’s flat terrain compared to yours.
If you’re going to get a different truck then keep the weight and try different ways of getting up that hill or hills.
Locker (as said above) isn’t a good idea.
Pennsylvania doesn’t lack for truck scales. CAT SCALE is a chain associated.
The SHERLINE scale is a tool you’ll be glad to have. Aim at TW being center-of-range (2k scale puts 1k halfway).
But it’s not the same as setting a WD hitch. Here’s some starter:
https://www.rvlifemag.com/taking-the-mystery-out-of-torsion-bars/
https://www.rvlifemag.com/understanding-ball-mount-angle/
1). Adjust the hitch ball height to 'level' the trailer
2). Adjust the weight distributing bars to 'level' the tow vehicle.
3). Adjust the hitch head angle to 'level' the bars.
At end of this rough-in, trailer should be dead-level for best braking and preventing tire side slip (load on both axles closer to equal). Not nose down.
At the scale:
How to Determine FALR
1). “If you want to use the scales data to determine tongue weight, and if you want to get the maximum information about your TV/TT combination and how well your weight distrtibution system is working, you need data from three weighings. Second and third weighings usually are done at a lower cost.
And, you need to find a scales with at least three separate weighing platforms so you can separately measure all three axle loads at the same time. Most, perhaps all, CAT scales have this feature.
First, the TV and TT should be loaded approximately as they would be for camping.
Second, the weight distribution system should be adjusted as it normally would be for towing.
Then, I would do the following:
Weighing #1 -- TT attached and Weight Distribution Activated
Let Front Axle Load be "FA1"
Let Rear Axle Load be "RA1"
Let TT Axles Load be "TT1"
Then, while in same position on scales, take
Weighing #2 -- TT attached and Weight Distribution Not Activated (WD bars unloaded, but hanging in place)
Let Front Axle Load be "FA2"
Let Rear Axle Load be "RA2"
Let TT Axles Load be "TT2"
Then, drive off scales and drop TT. Return to scales and take
Weighing #3 -- TV only -- TT Not Attached
Let Front Axle Load be "FA3"
Let Rear Axle Load be "RA3"
From the above values, you can calculate:
TV weight = FA3 + RA3
Gross Combined Weight = (FA1 + RA1 + TT1)
{should also be equal to (FA2 + RA2 + TT2) if scale weights are correct}
TT Weight = Gross Combined Weight - TV Weight
Tongue Weight = (FA2 + RA2) - (FA3 + RA3)
Load Transferred to TT Axles
when WD System is Activated = TT1 - TT2
This procedure should get you on and off the scales fairly quickly and still provide all the data you need.”
Afterwards (however many adjustments needed):
A. The combined rig will stop faster 30-0 than the truck loaded same will solo.
B. The feeling going down the road is that it’s on rails.
C. Find lockup point on loose surface at low speed with observer and adjust brake control to avoid lockup till later.
Keep the printed scale ticket with notes on final rigging adjustment. Future changes will be minor.
Adjust tires to value required. Not too high.
