2nd Gen Non-Engine/Transmission Need Tow hook help!!
Engine/Transmission (1998.5 - 2002) CPS question
Can someone tell me if dodge makes a front tow hook for a 2002 2500 I cannot find if so how much trouble are they to install
We dont need them. they are for getting towed by someone else :-laf. If you had a ferd you need them. Id like to know if they make one also. I havent ever seen one on a dodge
from dodgeparts.com
https://www.dodgeparts.com/advanced...+hook&osCsid=11d3218afbd35d4d94572c252e237907
Tow Hooks (1994-2002 ) (Part Number-82204881)
Click to enlarge
Tow Hooks rated with a towing capacity up to 5,500 pounds (depending on vehicle). These tow hooks securely mount to the frame and are fully tested for durability and load capacity. Available in black finish. Note for the 1999-2001 Ram sport pickups, front bumper fashia must be modified.
Does not fit 2002 1500 RAM.
Fits Model: Ram Truck
Fits Model Year(s): 1994-2002
Price: $132. 00
I bought an aftermarket one and some grade 8 bolts. I think I may have drilled one hole, can't remember but I used it yesterday to pull a new Dodge out of the ditch, worked fine and much cheaper than the factory ones.
Forget tow hooks. Get yourself a front mount receiver hitch like the one I put on my truck. It's made by Curt (p/n 31604)and didn't cost much more than the tow hooks mentioned in a previous post. Mine has stood up to the test of my Warn HS9500 making several max pulls while double-lined. It's also really handy for working on the engine if you fab up a simple step. Add a receiver shackle bracket and you have a really strong pull point that a strap cannot come loose from.
Custom Trailer Hitch Products, Custom Receiver Hitch, Heavy Duty Towing, Curt Manufacturing
Yes tow hooks are available. I put them on my 01 a few years back. Installation is very straightforward, they bolt right up to the front ends of your frame. If you have a plastic air dam on the front, you will need to cut out a rectangular piece of plastic to allow the hook to protrude through (the cut-line should be molded into the plastic). I am not sure if the hooks are compatible with other add-ons such as steering stabilizers, front receiver, etc.
