Need transfer case linkage photo
Intermittent light surge at hiway speeds.
Code: P2609
To keep it from grinding you need to move the lever fast(er).
As soon as your TC moves into Neutral the input shaft spins up just by the drag forces inside the AT and that causes the TC to grind going into gear again. This can be avoided by moving the lever quick.
Another way is to have the AT in P for the shift so nothing moves and you have all the time of the world to do the shift.
This has nothing to do with speed at which I am shifting it. Fast or slow, it grinds. I have owned this truck for 16 years and have shifted it in and out of four-wheel-drive who knows how many thousands of times. It didn’t do this before.
Another thought… Could someone who has a similar vintage 2500 please crawl up under there with a tape measure and measure the length of the shifter rod that protrudes forward of the bracket that holds the securing bolt? It’s apparently quite sensitive as to where it’s positioned.
