New 2018 3500 Dually 4WD Questions
Ignition switch problem 2012 Ram
Trouble starting...battery problems?
CROW
How in the world do you get the old oil filter off and the new one on? Lot of "stuff" in the way on this 4 WD truck. Old truck was a 2005 2WD and oil filter removal was pretty easy.
What is the torque for the oil pan bolt? It may be in the manual, but I can't find it. I always use a torque wrench to tighten since my old wrist has lost it's calibration.
Thanks in advance for any answers.
Unless it's changed, the plug torque is 37 lbs, it's stamped on the plug......The oil filter is easily removed through the wheel well with a tool from Geno's.....or you can do it the hard way from under the hood, removing the air filter housing and intake ducting......o_O
Sam
I did a write up on this, from the "TOP" baby!!!
EASY! 2013 up oil change
