Just have several miles on my new rebuild...
First reaction is it seems to shift like new stock so that's OK... shifts pretty good, not very notchy or anything just a normal 5600 shift.....
there is one thing of concern. . in 1st gear, the stick wobbles front to rear a little... there is no noise and I don't feel any clicking of gears or anything... it feels like a shaft is out of round... . this only happens in 1st gear... . all other gears are smooth and good... . Since I only use 1st for towing take-off's and manuvering, I am going to see if it causes other problems later on... . have a 6 month warranty so I will see what happens...
I have the fast coolers on and when they did the rebuild, they painted the case so no more rusty 5600! ... .
I also had a bad U-joint on the driveline I didn't know about so they replaced that and greased the other one as well... Wonderfull shop! (six States Dist. here in salt lake)
So the redline MTL with the fast coolers makes like 7 quarts total in it... . that should help it keep cool while towing... had them overfill it 1 quart for the rear bearing problem.
Will be taking a trip to nevada next month, will update on how the trans. works... . I don't have a temp gauge in it at the moment so won't be able to see temp #'s...
So with engine rebuild ans transmission rebuild, I have a new truck for $10,000... . sure beats the new emissions trucks for 50 grand... . will get one eventually but for now, this will last another 10 years. .
