New Bedliner is in.
Powerlock protection system does any one have this
Wheel and Tire simulator ?
Just wanted to let everyone know my Line - X bedliner is in and what a nice job. It is thicker than Rhino and Diamond Liner. I asked for personal touches and really took care of me. I did the black and color is avalible, didnt want the 200. 00 more in cost. Lifetime warrenty covers everything except if you start taking chunks out of it from not being careful. Like if you were to throw a sharp edged piece of something in the back and it took a peel/chunk out of it. Repair costs are minimal.
I know what you mean about the Linex, I had one in my 1/2 ton and it was perfect. I like the surface, rough enough to keep most things from sliding all over the place but not too rough. Mine looked like new after 1 year of use. The (new to me) Dodge came with a bed liner, but will be replaced when I can "afford" the linex. $400 for under the rail here in Springfield. I have Rail caps so I don't need over the rail. I guess the benefit is that after they take out the old liner they won't have to do much sanding to install the linex :)
Liner type
I put in over the rail at the last minute. I also put a Raider Vagabond camper shell on and did a seal like a door seal between the shell and bed. The seals always rub the paint off so I did the over the rail liner coated. I also have diamond aluminum caps, all 4 and with the liner the sharp edged caps wont scratch the paint. I was going to put a thin flat seal like the old camper seals between the liner and cap to keep the water out and put the camper on over the caps with the new seal there. Should look real nice. In Reno Line-X has a contracter price of $330. 00 Under rail and $380. 00 for over rail. Both include front and tailgate caps and all inside. They also have a spray to keep the liner like new looking so it doesnt fade.
Line-X spray
Yes, Line-X says they have a spray that keeps it looking like new and no fading. I'll get the name and cost and size on Monday. I'll put another post here late Monday, Reno time zone.
