New CTD owner
speedo/odometer
Block Heater
I posted this elsewhere and was told this would be the best place for it. I'm new to CTD from the Ford brand. I still love my Ford's, but gosh the Cummins is amazing. I just got a 92 D250 auto, its in great shape and I intend to keep it that way. I was wondering if you guys have some preventative maintenance tips for me? I will prolly be posting alot on here, so I hope you all dont think I'm stupid and get tired of me asking, cause I wont get tired of asking. I figure its better to ask a question about something that you dont know, then to not ask and screw something up.
Josh
Lots of good tips are inside the thread at the top of the forum page - Best Tip for new owners..... etc.
If you'll read thru them, you'll pick up a sense of what's important for preventive maintenance and what options you have for improving the performance of the beast.
I keep my PM logs in an Excel spreadsheet, if you want that.
There's a tremendous amount of knowledge available from the folks here.
Welcome to the zoo!!
DBF :-laf
Yea I have read all the stickies at the top a few times so I have a couple ideas, I was just checking to see if there were anymore?
Ok.
I use the maintenance schedule in the owner's manual, slightly modified. I change oil every 6000 (less if I've been towing) and change the fuel filter every oil change (as well as the oil filter). I change the air filter every oil change when I'm towing or running in dusty territory. I use Fleetguard filters. The theory - keep the crap out of the engine.
Every second or third oil change, I send the old oil and transmission fluid samples in for chemical analysis. Keeps me aware of what's happening in the engine/trans.
I set the tire air pressure per the tire manufacturer's spec sheet for that tire; I keep all four on the ground the same for handling reasons.
My gage set includes tach, egt, boost, and trans temp. Each of these plays a part in knowing what's happening in the truck. Note the gage readings for several particular modes of operation so you can compare later operation with them - foot to the floor acceleration, going up a certain hill at a certain speed, etc.
I change out the other things pretty much at manual intervals - differential fluid, serpentine belt, packing the front bearings, engine coolant, valve adjustments, trans fluid/filters.
That's a start, anyway.
DBF
Where do you send it to and how much does it cost?
