New Dodgezilla
Towing with Bullydog 3's
AFE Stage 2
Darn it I guess I bought a couple weeks too early lol. Bob how does that 63 mm wheel spool up compared to the 61mm on the dodgezilla?
Originally posted by renegade681
Well I figured I'd give an update. I finally spooled it up on I-25 north bound. I seen 35lbs of boost in 4th gear and 5th gear with the box on 5X5. Egt's are still out of this world :eek: . 5th gear at 2900 rpm the egts are going past 1600 but its doing it slower than stock. And I'm seeing 7lbs fuel preasure. So my question is do you think it would help me to try and get it up another 5 psi? Do you think it would help that much more?
Other than that It's sweet, sounds good running down the road and when it spools up oh hell ya :D . Well its time to go do some running around.
What housing are you running? Thats interesting. . before I moved out here from Denver area my HTT Stage 3 with the 16 housing and similar fueling mods got me 42 psi and about 1450 degrees. With Water meth the heat was less and the boost was more. I think the HTT and the Dodgezilla are very close to the same arent they?
Jeff
Hey jrandol hows it going, hows the new location treating you? As far as the housing I went with the wastegated 14. And I think your right both turbos are pretty close to the same concept. I know I've read on here somewhere that with the drag comp the egts are kinda high, so maybe thats part of my problem. I figure later on this summer I'll also try the water injection hopefully it will help.
there was a miscommunication
Originally posted by Bob Wagner
And the new Dodgezilla HX40 is also available with adjustable boost on the fly :D
The Dodgezilla HX40 incoprorates a turbo-master wastegate which is not adjustable on the fly.
just for clarification :)
Jeff
Depends on what you are calling close. When we were developing the Dodgezilla we started out with the 60mm wheel and housing which worked very well. But after trying the 62mm wheel and housing we never considered going back. They are both good turbos it just depends on how close to the best you want. Hope this helps
Tim
