New Dyno Owner Needs Our Help!!
2001 Fuel Mileage
DD Stage 6 in R&D
We are planning a Dyno Day in the St Louis area on the 28th of this month. the shop owner of the Dynojet 248 has never run a Dodge or Ford Diesel on it. we currently have 4 Dodges and 3 Fords scheduled to climb on.
This is where we need the TDR's help, where can we get a Good Tach source for both the 24V's and 12V trucks? and if anyone knows we need one on the PSD's too.
Todd,
2001 Q-cab SB 4x4 5spd 3. 55's,PowerMax3 adj. , A pillar Boost/EGT,4" turboback exhaust,custom built aluminum airbox W/K&N-RE0860 through the cowl, and more to come...
Todd
Both of the Dynojet 248s I've used have an optical pickup that gets RPMs from the balancer on the crankshaft. It has a magnetic base that mounts to the frame and a piece of reflective tape is stuck to the pulley.
Dean
he only has two different sizes of inductive pickups right now. any ideas?
Todd,
he will have to order the optical pickup for you to get both hp and trq.
jim
if it ain't broke fix it till it is!!
2001 eth, ez box, dd2's,southbendclutch
My Ram Pics
Where and when is this dyno testing going to take place ? ..... and how much $$$ ? I live close enough for St. L to be a convenient place to possibly get mine tested also ... if I can rearange my scedule on short notice. I will certainly try #ad
John
2K Auto, 354 gears, VA and BLUE box, 4" exhaust, Auto Meter EGT and 60# Boost Guage, pressure lock,(soon to be replaced by DTT VB and TC) every option but the sliding rear window and snow plow prep. and sport package
Be sure to not just rely on the magnetic base to hold the optical pick up in place. Even strapped down with plasic ties, have the operator tie a safety line from the pick-up to the hood latch in case it vibrates loose.
Your fan will make quick work of it #ad
Y2K Awesome Black LB 3500 QC SLT, 24Valve ETC ISB, 4x4, 4:10 LSD, DTT Custom prepared Auto transmission VB, Power Edge 'EZ', DD2's, K&N, Polished Stull Billet Grill/Fog inserts, Chrome Smitty-Built Step Rails, Mopar Chrome-Tipped Mud Flaps, A-Pillar mounted West-Tach Turbo/Pyro/Trans Temp gauges, Rancho 9000's, Diamond Plated Tool Box, + a bunch of other stuff. Fact:The First Fords' had 'DODGE' Engines! The new PSD's need them!
