New Dyno Test Report
What tool is needed
Heater motor--replace or lube?
Ran my truck on the dyno again to see how the new fuel system and reprogramed puck work.
302. 3 HP
753. 0 Ft*Lbf
I will post the actual test reports once I go get them scanned.
Yeah Cliff, this sounds more like it. Remember at Bob V's when I said you should be sitting about 300? Good work!
Cliff....
Are those dyno numbers with 275's, the puck, modified fuel system, 35" tires & everything else stock? If so, nice #'s!:D
BTW, what did you do to modify the fuel system?
Re: Torquey little bugger
Originally posted by Vaughn MacKenzie
Man, look at all that torque. Still above 500ft/lbs when the graph ends :eek:
Very cool Cliff! :cool:
Vaughn
hehe, yep, that is why the stock clutch went TU so fast... and my heavy right foot :)
yes, that's it.
I moved the factory lift pump to a location by the fuel tank, replaced all banjo's with -6 fittings... . works great
