Will this new timing box only advance timing or will it also add more fuel like the VA?
If it only advances timing is it comparable to the VA timing advance, or is more/less? If it also ads fuel, does it ad more or less than the VA?
If you have a ""Power Edge" will this new box wire in with it or is it a seperate wire harness? Can the two be combined into one?
Most importantly, what is the difference in cost between the two?
Always ready to help!
2000 2500 Red Sport quad cab, 4x4, K&N, DDI's, straight piped, boost, pyro and fuel pressure gages, Hot Power Edge, mean looking set of 33. 5" tires, Snap On diamond tool box, Marine Corps window sticker, Semper Fi!
1972 340 Cuda'. Original tripple Black, 340 car w/air. Good clean car, super stock springs, Weld Prostars, shaker hood, strong 340 with a 727/4000 stahl, 4. 56... . Bombs away!
NRA Life Member. http://www.geocities.com/chadsheets
