New EGT gauge trouble! FIXED!!!
Hey guys,
My new Di-Pricol Optix EGT gauge is acting weird. At first it was working great, but then all of a sudden the readings started getting funky.
Sometimes I will go out first thing in the morning when it is about 35 degrees out and the gauge will be reading 210*. The when I run the truck it seems to be reading high. Then, when I park it, and let it idle, the gauge won't drop back to 300 even after letting it idle for 5-10 min. It hovers around 400.
I disconnected everything and hooked it all back up and the gauge dropped back down to normal levels. It worked fine for a couple of drives and then last night, it was reading high again. I pulled the fuse from the (+) wire and rehooked it and it was back to normal.
Does this sound like a gauge problem or a wiring problem? I wired it just like my old truck which worked great. Any clues here?
Thanks,
Chris
Hey guys,
Thanks,
Chris
