WHazelwood
I just installed the Isspro gauges from Geno's last week and at idle with ambient temp in the 90's the egt is reading 450-500. This seem high?
Accelerating from a stop I can peg the Boost gage (30psi) and the egt goes to 1100 deg and the truck is empty. Probe is pre turbo just after the no. 3 exhaust on the top of the manifold This also seems high?
The trany temp is in the 2nd test port on the pasenger side; used an 1/8 close nipple, 1/8X1/4 reducer, 1/4 close nipple, 1/8X1/4 reducer and temp probe. Seems to be reading the under hood temp rather than trans temp, cause when I go through a rain puddle the temp drops to 100 from 160. I'm going to order the Mass Cooler line to change that. Are these no's Ok and what do I need to watch when pulling the 5er?
Thanks
Thanks
