Just returning from a Sunday drive on the logging roads in the coast range in north west Or. I went to hose off the dust and found oil on the tailgate, assuming it was gear oil, looked at rear axle, nothing. Looked to the front, oil running off front diff. Upon closer insp, running off the block. Had changed oil a few days ago, so I checked filter, drain plug, nothing. Checked pan bolts, tight. Now what, looking up the block oil seems to be comming from under the computer modual on the lower block driver side. I checked from above and no trace anywhere. Looking closer from under, looks like a plastic pannle behind the heat shield behind the computer mod.
I check under the truck a lot and other than the trans pan weeping a bit no leaks.
This leak is very new, maybe 5-10miles or so. The entire under side is dripping, and doesn't have dust mixed so it was after I was back on pavement.
I am once again afraid to drive my very expensive driveway
filler. Am I missing the 500lb gorilla?
I don't know much about the daily workings of the 6. 7
Checked P/S, nothing
Checked fuel filter and all the lines, nothing
Oil level on stick "full" same as when I changed it, Mopar oil filter, Shell rotalla T.
Only eng mod is K&N air filter
45436 on the clock, I am original owner
No codes
Can or should I drive the 20 miles to dealer?
No codes
