New lift pump installed
auto trans line pressure
Strange Problem with the engine
Finally got the new lift pump picked up and installed last night. The full set of Ray T's banjos went in at the same time. I discovered I'm not that good at working blind, so I went ahead and removed the fuel filter canister to give me a little more room.
Much nicer to see the higher readings on the fuel pressure gauge (all measured at the inlet to the VP44):
Idle - 15+ psi
3000 rpm (no load) - 13 psi
Cruising (55 mph) - 13-13. 5 psi
Going to redline in 3rd - no lower than 9 psi
Now a couple of questions for the next time:
1) Anyone else had trouble with the 1/2" mounting nuts being on so tight that the studs back out of the pump? All three of mine were that way. Once I discovered the 7/16" nut under the plate, it made getting the studs out of the bracket easier. Just curious if anyone knew a way to keep this from happening.
2) Repriming the fuel system. Is there anything that should be done to make the pump pick up fuel faster after the install?? I cycled the pump by bumping the starter 7-8 times and it never picked up any fuel. Finally I pulled the fuel filter cap and filter and bumped it again, then it picked up right away. I had my line to my sender open so I figured it would push all the air out of the system that way as it primed. I guess I was wrong. Do you typically have to remove the cap to get it primed?
Thanks as always (saved me having to leave the truck at the dealer for a couple of days)
Justin
justin , the factory puts red loctite on the studs , thats why that happened , no way of avoiding it , if you didn't put any on the bolts you should be ok . i pull the filter also , much easier .
pressures look right on target .
as far as priming , the problem was air trapped in the system , i usually hold the bleeder on the schrader at the VP open , but i removed it , so now ???? i guess that popping open the filter canister will do well at displacing the air pre filter .
what happened is pretty typical . you could also open the fuel drain and put a container under it and wait till fuel comes out in a steady stream .
Thanks MM
I figured since I had the hose to my fuel pressure sender opened up, it would allow all the air to escape. Oh well, guess it wanted me to work just a little harder on it.
