amsoilman
Staff Alumni
Just returning from the “AMSOIL UNIVERSITY” in Superior Wisconsin, and Amsoil has a new transmission fluid for the NV-5600 transmission! It is called (MTF) Manual Transmission Fluid, and is a 5W-30 designed for certain manual transmissions that require an engine oil (GL-1) formulation, which will perform even better than the (HDD) Series 3000 5W-30 engine oil. This new technology will provide improved gear and bearing protection and smooth synchromesh shift quality from –40 to 300 PLUS Deg. F. It is NOT for use in engines!! It has the Chrysler spec MS-9224 and MS-9417 as well as the Chrysler part #4874464 & 4874465 printed on the containers. MTF is recommended for oil drain intervals up to 2 times longer than OEM.
After seeing the “SPECS. ” On this lube, I am going to drain out mine and install this fluid! It is some awesome stuff!
The other Manual transmission fluid is (MTG) Manual Transmission/Transaxle Gear lube GL-4 which was designed specifficly for NV-4500 transmissions in Both Dodge and GM trucks. It has the Chrysler part # 4874459 and the GM part # 12346190 printed on the containers.
These two fluids will be available after the 1st of June.
Wayne
amsoilman
Wayne
amsoilman
