Kernel said:Can anybody PM the cost of the fluid for the NV4500? Thanks.
Scott
They quit making the gear lube that they recommend for the 4500, so they needed one there.
boonsur said:Has anybody been able to try this yet???
I just installed the Amsoil MTF (Manual Transmission Fluid) in my 03' NV-5600, and have about 100 miles on it since install. My truck has had the Amsoil 3000 HDD (Heavy Duty Diesel) 5W-30 for the past 38,000 miles, and there doesn't seem to be alot of difference as far as shifting is concerned. It still shifts VERY smooth, and no noises at all. When I drained the HDD out, it was still a nice Golden color, and was transparent. The MTF does have a wider temperature range (-40 F to 300 F) so it should be better in the cold temps as well as hot.boonsur said:Has anybody been able to try this yet???
tomeygun said:FYI - Just got the MTG trans fluid in the truck (10 minute job when I am here at the dealership with an oil change rack and a fluid pumper)![]()
I'll post on what I think after a few hundred miles
PS - my 36k mile fluid still looked new, BTW
Hohn said:Who in their right mind would use motor oil in a transmission? Stir, stir... .:-{}
jlh
MBreyer said:Just a bump to the top.
I've got the 4500 & use the recomended synthetic (Valvoline??) & it's a sticky shifter. I know, it's the transmission's characteristic.
Anyways, I'd like to try out the Amsoil MTG stuff. Is there a "best" place to order from? Should I look for a local dealer, order from the company, or ???
Thanks guys.
~Matt
P. S. Is it worth switching from conventional oil in a rig w/ 180k to something fancy??
amsoilman said:Film strength and Viscosity do correlate, but in every book on oils I have read, and all the schools I have attended on oils, "Viscosity is the single most imoprtant property of lubricating oil"! If the oil is "Shear stable", then it has better film strength.
Wayne
amsoilman
