Well I guess I gotta pull my foot from my mouth here, I do remember having once owned a dual wheel Motor Home how important matched air pressures were in the duals and that not having them matched will cause the higher inflated tire to drag the lower inflated tire as it will travel farther so I started looking for the info and found this:
Matching pressures is especially crucial on dual assemblies because an inflation mismatch greater than 5 psi means that the two tires in a dual assembly are now significantly different in circumference.
But, because they’re bolted together, they have to cover the same amount of road in a single revolution. So, the larger tire drags the smaller one. Very fast or irregular wear – especially on the tire with less inflation – can be the result.
In one test we made, a 5 psi difference created a 5/16” difference in tire circumference.
In a single mile, this 5/16” difference causes the smaller tire to be dragged 13 feet. In a typical year’s usage of about 100,000 miles, that comes out to 246 miles.
Again, it doesn’t sound like much until you remember that the tire is not rolling an extra 246 miles, it’s being dragged. In other words, it’s as though you spun the tire against the pavement for 246 miles! At 55 mph, that would be about 4-1/2 hours of wheel-spinning.
Sometimes we forget what we learn, worse yet start running off at the mouth to boot!
