see here:
http://www.tstproducts.com/index.asp?PageAction=VIEWPROD&ProdID=135
No more sending in for a twins flash!
Detailed Description
NEW Lower Price with More Features
Programs in ALL NEW POWERMAXCR™ R49's
What it does
• Economy Setting
Geared toward fuel economy
• Standard Setting TST's Original Programming
• Early Twins Setting 03-04 Twin Turbo Programming
• Late Twins Setting 04. 5-06 Twin Turbo Programming
• Adjustable Timing Setting User Control timing up to 18 degrees
• Auto Cool-Down Turbo Cool Down Control
• Adjustable Rail Pressure Control added rail from none to ...
As well :
Rail Pressure Gauge: This screen is optional and will only display if you have the rail pressure option (only available for some TST POWERMAXCR™ serial numbers 5000 and above). It will display the rail pressure in thousands, so 15,500 psi will display as 15. 5.
Rail Pressure Control: This screen is optional and will only display if you have the rail pressure option (only available for some TST POWERMAXCR™ serial numbers 5000 and above). It will control the rail pressure increase, OFF (stock, no rail pressure increase), 1, 2, . . . up to 9 levels. On the Economy program only: the last level is rail pressure reduction, which shows “-9”. This is for when you need to reduce smoke. It reduces rail pressure to cut power about in half. On all other programs, level 9 is the maximum rail pressure increase. On the tt05/tt03 programs only: Warning, rail pressure levels 8 and 9 will exceed both the sensor and bypass valve limits and will most likely blow the bypass valve.
What it does
• Economy Setting
As well :
