new muff from dpp
Did Tim get his darn truck?
Vistronic fan operation
skorski
Got my new mufff from diesel performance yesterday. Put it on and it sounds great :) :) One thing i did notice is the smaller amount of boost. Before it was about 6 or 8 at 55 now it is 2 to 4 at 55 sometimes 0 . Is this goo or bad etg seam a tad lower also :confused:
I installed the same muffler on my 04. 5 on Sunday. The install was fairly straightforward, removed stock muffler using a sawzall, trimmed the pipes to length and clamped everything in place. There is only a slight increase in in-cab noise and the truck seems to run a little freer. I don’t have any gauges yet so I don’ have any hard number to compare. I hope this frees up a couple more MPG with fuel running $2. 63 a gal.
Mark the install only took 30 min i went to midas i don't have a life thanks for a nice product . Again just adjust the lenth and cut the oldone off with a sawsall.
Mark,
I ordered 2 cat test pipes and 2 mufflers from you about 3 weeks ago (before my trucks came in). The pipes & mufflers went in great, took me about 45 minutes per truck. I used 4 inch SS band clamps on the Cat test pipes, a band clamp on the pipe to muffler inlet, then trimmed about 4 inches off the tail pipe and welded it to the muffler.
I LOVE the Sound! and the system could not have been easier to install.
Is it physically possible to bolt the 03-04 MBRP exhaust in place on an O5? I ask because you can only buy a cat back system for the 04. 5-05.
A "cat test pipe" is a replacement piece of 4 inch pipe (properly bent) to fit in place of the cat. Also commonly refered to as a Cat delete pipe - just replaces the CAT.
NAUIdvr1
Just wanted to thank you guys for your input. Had the mbrp muffler installed yesterday and it does as promised. Nice rumble when you get on it but no drone at all. EGT's dropped about 50 degrees. Nice product.
