Well... I finally pulled the trigger and bought a weed whacker. As usual, I analyzed my options ad nauseum and tried to come to some sort of conclusion. The choices in 4-stroke models are somewhat limited by comparison to the much larger number of 2-strokes out there. So, my research was restrained more by product availability than anything else.
I looked at the Ryobi, Troy Bilt and MTD (all the same thing as the Ryobi) and they weren't built as nicely as the Craftsman and didn't have the B&S engines I read so many good things about. I ended up with a Craftsman model from Sears.
With the biggest displacement engine out of all the 4-strokes (34cc Briggs and Stratton 'L-head', NOT overhead valve) it's substantial, but felt well balanced in the store and seemed as though it was built very well. The salesperson was not terribly insightful on this model, but that shouldn't have surprised me.
I can now honestly say this is the coolest, best built, most refined weed whacker I have ever used. I filled it up with SAE 30, put some gas in it, hit the primer 8 times and gave the recoil start a gentle pull. I didn't even have the cord all the way out and this thing was idling like buttah. It's unbelieveably smooth and I think it's very quiet by comparison to a traditional 2-stroke engine; especially when you don't have to rev it up much at all to get the job done.
Since this model has a centrifugal clutch, it will sit there and idle just as smooth as can be. I actually stood there looking it over for a good five minutes after I was done with all the trimming in the yard in amazement of how smooth it runs. When trimming, I never had to use any more than 1/4 throttle... it seems to have a lot of torque which is one of many benefits of 4-strokes.
The line spool couldn't be easier. If it takes you longer than 10 seconds to put new line on it, you're a slacker. That may be this model's biggest drawback. It uses these almost foot long pieces of trimmer line that looks like Twizzler's candy. You stuff it into the holder and you're done. No bumping it... no fuss... no muss. The advantage of this line is that its shaped so that it makes less noise and is horrendously easy to install/remove. The disadvantage is that you might have to buy it at Sears. I haven't gone looking for it yet as the machine came with enough to probably last me halfway through the season. Since the line is cheap at Sears ($3. 50)... I may just keep picking it up there when I need more.
I'm now a very firm believer in 4-stroke weed whackers... especially the one I just bought. Check it out on this link if you'd like to.
Matt
Matt
