My friend installed a 40 hp plate from bullydog last night and has complained that he recieved no noticable power increase with the plate itself. He said that the afc starwheel adjustment made more of a difference than the new plate. I was just wondering if these 2 adjustments have to be done together to see rersults or there is something he should check out on his truck for possible problems? I don't if it matters alot, but in the kit was a 90 degree brass fitting that went into the wastegate. He didn't put the fitting on for reason I don't know. What was the purpose of that fitting and will it make any difference to the performance of his truck? Thanks for your help.
cody
91 4x4, 5 speed, 3. 54 gears, pw injectors, 12cm turbo housing, K&N air filter, "tweaked" pump, isspro boost and pyro gagues w/A pillar mount, straight piped 3' exhaust
cody
