New plate, no power
transmission life expectency
Southern Rams anti-freeze
My friend installed a 40 hp plate from bullydog last night and has complained that he recieved no noticable power increase with the plate itself. He said that the afc starwheel adjustment made more of a difference than the new plate. I was just wondering if these 2 adjustments have to be done together to see rersults or there is something he should check out on his truck for possible problems? I don't if it matters alot, but in the kit was a 90 degree brass fitting that went into the wastegate. He didn't put the fitting on for reason I don't know. What was the purpose of that fitting and will it make any difference to the performance of his truck? Thanks for your help.
cody
91 4x4, 5 speed, 3. 54 gears, pw injectors, 12cm turbo housing, K&N air filter, "tweaked" pump, isspro boost and pyro gagues w/A pillar mount, straight piped 3' exhaust
NeedMoPower
I'd make sure your friend followed the directions completely. Like moving the AFC housing forward ect.
I'm not sure why he didn't install the turbo boost contol barb. This will let boost bulid from about 18 lbs stock,(depending on year truck) to approx 30 lbs boost, before the wastegate opens. This will make the added fuel burn clean.
He should have a 'decent' power gain from a 40 HP plate. But not a neck snapping power increase you would get from a 100HP plate. #ad
If the new plate is installed slid rearwards from the stock position he may not see much power gain also. Have him try slideing it forward little by little and he will feel a difference.
95' 25004X4,AT,Driftwood,Banks Stinger,Warn fender flairs and running boards(work truck)
95 3500,5 speed 3:54,Driftwood,Banks&Psycotty,34,000 GCVW apple and tractor hauler(works harder truck)
NeedMoPower,
If he is not getting full throttle the plate won't make any difference. Have to check that. I had that problem when the screws that attach the throttle lever to the lever on the side of the pump at the rear were loose. There are two of them with 8mm heads.
Joe George
Eureka, CA
'95 2500 CC auto 4X4,3. 54,Combo EGT/boost guage,custom switch panel,PacBrake,TST #5,BD valve body,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver
Originally posted by NeedMoPower:
... . I don't if it matters alot, but in the kit was a 90 degree brass fitting that went into the wastegate. He didn't put the fitting on for reason I don't know. What was the purpose of that fitting and will it make any difference to the performance of his truck? Thanks for your help.
cody
[/B]
They just put the fitting in there for a paperweight to keep the instructions from blowing away while he's not reading them #ad
Here's your friend's sign #ad
Seriously, though, more fuel + more air = more power. Your friend left out the "air" half of the equation. All the plate by itself will do is dump more fuel in. You have to have the boost fitting to add the more air to burn the more fuel to get the more power.
Daniel
95 2500 SLT Laramie 3. 54, automatic,Herculiner bed liner, JVC cd out of factory infinity system, southwest grill gaurd (a favorite amongst the deer population), K&N chunked, AFC adjusted, dual straight exhaust out of "gutless" cat, Geno's dual EGT/boost gauge, TST #6 plate slid all the way forward, AFC housing slid all the way forward, silencer ring removed
"Layin' the 'SMOKEDOWN' on their ROOdy Poo CANDY GASSERS!"
The AFC allows more fuel to be added when more air is added. If more fuel is added without more air, all you get is more smoke. Your friend is not getting any more fuel into the motor than before, because he still has the same amount of boost. The elbow allows more air to enter the motor (by "adjusting" the wastegate), then more fuel can be added, then you get more power. The elbow and the plate work together, hence they must both be installed.
'97 2500 CC 4X4 5spd Sport
'83 K5 Blazer 350 TBI (ex 6. 2), 39. 5 TSLs, 3" lift, Dana 60/GM 14 blt, Detroits
Thanks for all the responses guys... . ya'll really cleared up the problem. I personally haven't looked at his truck so I really don't know what he's talking about. I told him to put the boost fiting on, but he was complaing that the old fitting won't come out. Is there some trick I should tell him about or is my friend just a dumba$$. #ad
Thanks for all the help once again.
cody
Just put my TST #8 plate in, it really is nice!! I moved it a little forward of stock position. I did put the turbo boost fitting on, boost is even higher now than before when cruising. On hard pull the egt goes to 1350 deg F. The truck now gets up to 95 very fast! 95 is where it governs out.
Tell your friend to do it right, it should work.
I also put all new bolts in AFC cover, 10mm hex heads, they worked fine, now they are all the same.
96 CC 4X4 2500 SLT AUTO transmission, PrimeLoc, ISSPRO EGT Boost transmission Temp, GUTTED CAT, 150,000+ Miles still goin' strong, Lots of Ham Radio gear, NO IGNITION NOISE!!! Love my diesel!!! # 8 TST Fuel Plate.
