I used Loctite brand Teflon thread sealer "pipe dope" on all threaded connections, making sure I kept the sealer away from the ends of the fittings. Seems to me I had a slight idle problem for a few startups after adding my Prime-Loc, nothing too serious though. Over the course of a day or two all the remaining air was purged from the system.
In the event that is not excatly your problem, did you make sure the two remote mount hoses were connected in the EXACT manner described in the installation instructions? Also, are you absolutely sure the large O-ring on the remote TAKEOFF mount (that is bolted in place of the OE canister) remained in place during installation? Additionally, if you mounted the Prime-Loc flow restriction gauge, did you make sure you added the two small O-rings at the appropriate port locations? Are they both correctly seated?
'98. 5 2500 QC 4x4, (BLACK) SLT Sport, ISB, LWB, 3. 54 LSD, A/T, Glasstite Vision II canopy, Line-X bed liner, 285/75R16 BFG A/Ts on 16x8 M/T Challengers, Warn 4X Boards, Mopar fender flares, front and rear NW Custom stainless steel/rubber mud flaps, Mag-Hytec diff. cover and trans. pan, Edelbrock IAS shocks, Mopar tow hooks, Reese Titan V hitch, Jordan Research Ultima 2020 trailer brake controller, VDO Vision gauges, '00 Sport grille, '00 Sport headlights with PIAA Super White 9007/9004 bulbs, 4-2-7+4 Brite-Box, PIAA Dual Sport 900 auxiliary lights, BD exhaust brake and TorqLoc, Prime-Loc fuel filter relocation kit, Bosch 275 hp. injectors, VA CPC, DD Boost Module, Banks Stinger wastegate actuator, BLACK '00 valve cover, Banks Stinger 4" dia. stainless steel exhaust system, BD LV V10/Cummins hybrid TC and valve body, BD modified transmission front pump and PressureLoc, plus many other trick modifications
