Here goes an attempt to explain what has worked for me. I have done the rear brakes on both my trucks in the past year. I tow quite a bit and am hard on brakes in general. I went back to drum brakes on the W-250 because the rear disks performed less than desired. I am running 1" wheel cylinders and 3" shoes on both trucks. The dually has the RWAL valve removed, the 3/4 still has it. No difference in braking because of the RWAL valve. The reason I went with the 1" wheel cylinders is as follows. A MC has a set amount of fluid flow and pressure that it is capable of delivering. The 1. 125" cylinders are able to exert more force on the shoes, however it takes more time for them to react or fill. The 1" wheel cylinders bring the rear shoes in faster. On both trucks you can feel the rear brakes working with each stop. When I had 1. 125 cylinders on the W-250, I couldn't ever feel the rear brakes working unless I really got on the brakes hard. The fronts were doing most of the work because hey were already applied when the rears were just starting to come in. Both trucks can readily lock the rear wheels up in a hard braking situation. Towing is much better now that I know I have faster acting rear brakes.
Now for a bit of a sermon. When you do rear brakes, have the rear drums turned or replaced. I bet there isn't one guy out there who can spot an out of round drum by eye. If the drum is out of round, you loose a lot of effective contact area for the brake shoes. Obviously replace the shoes. Change the adjusters, springs, and adjusting cables (adjuster and small parts kit at NAPA). The adjuster cables will stretch over time and use. The last set I compared (new to old) had a 1/8" difference in length. Take the anchor bolt apart and make sure it works freely. If you don't do those things, then your efforts of a brake job could well be wasted. Dodge brakes are effective if they are setup right. It will cost some money to do a brake job, but like Andy and Stan said, you have to pay to play. Hope this helps some guys out.
Jeremy
