I had previously owned Ford 7.3 diesels while I was shoeing horses. I am now retired. This is the vehicle I just purchased.
2014 Ram 3500 Laramie, Crew Cab, 4WD, 8.0 FT Bed, 6-Speed Automatic
68RFE Transmission, 6.7L I6 Cummins Turbo Diesel Engine, Single Rear
Wheel With 3.42 Axle Ratio:
I intend on pulling a fifth wheel rv. based on the following stats
Gross Trailer Weight = 16910 lbs
Gross Vehicle Weight Rating (GVWR) = 12300 lbs
Payload = 4380 lbs
Base Curb Weight = 7918 lbs
GAWR Front/Rear = 6000 lbs/7000 lbs
Gross Combination Weight Rating (GCWR) = 25000 lbs
In your opinions, am I safe to pull a 16900 lb RV? Or is that over taxing the system? I realize the above factory info says I can pull a 16910 trailer...I just would like a practical opinion on if it is advisable with that rear end. I compromised the rear end to facilitate better fuel mileage.
On a 16000 lb load, what mpg would you expect at 60mph? Also, due to the miserable fuel quality, what additives does this forum recommend for use on a regular basis.
Any information is appreciated.
Payload = 4380 lbs
