Ok i got my new smarty today and loaded SW 1, it's very responsive in the low end, a tap on the throtle in nuetral just about red lines, it feels like a new truck,
But i do get allot of injector noise ( TsT unplugged ) i guess it's timming rattle??
Now my problem is this, before smarty stock ecm when my key was turned on my fuel pump would run for a couple of seconds and cut off untill truck was started then start again, so i was starting with zero fuel pressure, now with smarty pump runs continuosly, truck starts with 17 psi fuel pressure, even after i had Smarty return ecm to stock.
Questions
Can i download with my VA 3. 1 installed since it's installed directy in the ecm harness??
Wich has more timing standard TST or Smarty
and wich one hits full timming earlier.
Next week i'm heading out to Utah from Va. towing 10,000 lbs and i'm trying everything i can to get my millage up some,
Should i run Smarty with timming and no TST or Smarty no timing and TST for timming.
Thanx for any help or suggestions.
Rick
Questions
Rick
