New Style BD Outlook Hook-up Question
Looking for a new ECM.
NV5600/aftermarket clutch?
I have a new style Outlook that has the '03 to '05 sub harness. When I installed it I have no boost pressure and the check engine light is on. Either I have a bad connection or the spare female spade connection on the sub harness is a ground or something else. Anyone know or do I wait until Monday to talk to BullyDog?:confused:
Update: When MAP is plugged back to stock the check engine light is back off.
I've installed quite a few Bullydog Combos on the 03/05 Dodges and I've never had to use the Pink spade connector with the newer Outlook Monitors.
Did you take the factory male map sensor connector and plug it in to the Bullydog harness..... then take the male Bullydog connector and plug it in to the map sensor on the manifold ?
If you have all the connectors plugged in correctly, I would say the Bullydog Harness is bad.
I have a few laying around my shop and would be more then happy to send you another one.
hope this helps,
John
Thanks for the offer. I believe that everything is hooked up properly. I even read the instructions. :) Again. If I need a harness, I'll let you know. Thanks again.
