New Style ISSPRO Gauges
Problems with the TST
05 fuel pump pressure
I have to agree that the Isspro gauges match up very nice and are faster reacting than the Dipricol-----------I switched from the Dipricol to the Isspro and yes I had problems with the lighting on the Dipricol EGT gauge. I am very pleased with the new Isspro gauges and the only thing you have to hook up 2 small AMP boxes---1 for transmission gauge and the other for the EGT gauge.
Jim
DWestfall said:
Yes I love the new ISSPRO Gauges. They match perfectly to my 03 gauges. The lighting on the DiProcol EGT was dimmer than the DiProcol Boost & transmission gauges. The new ISSPRO are all exactly lighting up the same. I will strongly reccommend them.
I did notice one of my DiProcol gages was a little dimmer than the other two.
I just put a small resister in series with the bulb on the brighter ones, and they are now all three the same brightness.
I now want to add the DiProcol fuel pressure gauge. Will the Banjo Bolt that Geno's sells fit the 3rd gen?
It says it's for 2nd gen 24v.
They been working on the electric fuel guage for over two years, there not happy with it yet. Living in Portland i try to get on their beta test list.
WHO?
we have been talking about Autometer, isspro, and DiProcol.
which one wre you talking about?
RRoton said:
WHO?
He's talking about Isspro, which is based in Portland. I also have contacted them several times about an electric fuel pressure gauge and have been told "we're working on it" every time.
-Ryan
Ok Well Your On The Subject Who Makes The Best A Pillar Pod I Heard That Someone Was Producing A Pillar That Need No Mods????help Advise I Am Going With The Isspro By The Way
2003 SLT SHORT BED QUAD 48RE AFE PRO GUARD MBRP DUAL 304T EGDE EZ WESTERN BULL AND STEPS CURTIS PLOW BACK RCK TOYO AT AND FEDERAL SIGNAL BAR WITH 8 STROBES Oo.
-Ryan
Well, they're finally in. We have the new R6804R 0-30PSI white dial red pointer gauges in stock. If you want to take a look Click Here . If you have any questions I'll be glad to help.
Heres my dilema. i am getting the SRT-10 A-pillar. i want to put the pyro gauge in there as i believe it to be the most important. i would prefer the rainbow face in white, but the black is all i can find. i would then like to put a 3 gauge pod on the dash with a oil pressure, fuel pressure and 0-60psi boost. the problem i s i can't find a manufacturer that makes a white face matching set for the 3. thanks for any help.
srt-10 pillar easy switch
DKillarney I just went and bought the pillar from Dodge, I think it was somewhere around 60 bucks out the door. pulled old one out, put new one in, color already matched and everything. All you have to do it switch over one clip and the bolt hole covers and you're done. It came in the natural biege or whatever they call the color.
I put my transmission temp sending unit in the passenger side rear test port on the transmission. If you look there are two. I used the furthest one back. Works like a champ! I had to add about 2-3 feet of 18 gauge wire to the wires going from the sensor. I called Isspro and they are in the process of making the wires longer. They said you can lengthen the trans temp wires but you can't shorten or lengthen the EGT wires.
Well, that's a start! But it's mechanical!! I want an electric. :{
[I know, some people are never satisfied]
-Ryan
I've got Autometer Phantoms (6 of 'em). EGT is in the SRT-10 pillar. Oil, water, and fuel pressure are in the triple dash pod. transmission temp and 60psi boost are in the dual column pod. They're all white-face, and they all match (although the night-time lighting isn't as good as the stock gauges, or DiPricol, or the new Isspro's).
Now - I may have cheated a little bit. The 60psi boost came from Diesel Dynamics. It's an Autometer Phantom series, but it looks like it's custom-made for them (has their logo on the dial, and says "TURBO" instead of "BLOWER", like the one on Autometer's web page). It's part # 5802.
-Tom
I installed the Isspro pyro and boost gauges in my 93 crew and really like the looks of them, however the pyro is noticeably dimmer than the boost gauge. This might be do to the fact that my pyro doesn't work at all..... hopefully I can get this issue delt with quickly as I haul a 5000lbs trailer every day up a 13% grade and have no idea as to what my EGT's are.
I have those Isspro white face, red dial gauges coming from Diesel Manor. They are supposed to be here today. 0-60 boost, egt, and the fuel pressure gauge (mechanical with an isolator).
I'll take a pic of them (unmounted) and put it up here later tonight.
