Tires were supposed to be inflated to 70psi as per my specifications. I have not checked them.
Andy B
I don't know if you have worn parts, tire squirm, or air pressure issues. But, I want to share a recent experience that reconfirms to me how important proper inflation is. I have been running Michelin LT265/75R16/E LTX M/S tire for most of the life of my truck which is a t 240,000 miles now. Just recently my wife and did a 12,000 road trip to see the fall colors on the east coast area. The GCWR of our truck and travel trailer (using a weight distribution hitch) was right at 12,600 lbs (4600 front axle, 4000 rear axle, and 4000 trailer axles). Toward the end of our trip we passed through El Paso, Texas where I purchased four new tires (the same as mentioned above) because the tread was down to 2/32" on the old tires. I requested that the new front tires to be inflated to 55 psi and the new rear tires to 50 psi which was the same pressure I had been running for the last 10,000 miles. I chose these tire pressures based on the tire weight rating and the actual individual truck axle weight recorded at a weigh station.
After hooking up the trailer and heading west on Interstate 10, I noticed that the rig wasn't handling quite right. It felt like a rig I drove years ago that had mixed radial and bias ply tires installed. I felt a subtle side to side motion around 65 mph on a good road surface and no wind to speak of. The motion was more pronounced when other vehicles passed by me, especially larger vehicles. None of these symptoms had occurred before the new tires were installed. I was beginning to wonder if I was imagining this because it just didn't seem possible with new tires installed. After about an hour of driving, I pulled into a rest area and checked tire pressure. The truck front axle tires were at 55 psi and the rear axle tires were at 80 psi. I lowered the rear axle tires to 50 psi. We returned to the freeway and all of the previously mentioned handling symptoms disappeared and the rig handled very well, just the same as before I installed the new tires.
I have never heard of tire squirm before I read these posts. I don't discount that it exists for it seems that I am forever learning new things, just when I thought I had some things mastered. This discussion forum has prompted me to look into tire squirm and it does appear that it exists, it is just that I have never personally experienced it, at least that I know of.
If you do all of the prudent things (ensure proper tire pressure, check for worn steering and suspension parts, etc.) before you throw money at it, I think you will probably figure out what is going on.
- John
