PKnoerzer said:I hope to find out. I also have a heavy slide-in camper. They are load rated - 3415# ea.
I'm not trying to rain on anybody's parade, but they won't be great with a large slide-in. The load ratings are nice, but they aren't the important issue; sway is the issue with a large slide-in esp. on a SRW truck. Three things affect sway as far as tires are concerned;
- 1) Sidewall stiffness
- 2) Sidewall height
- 3) Air pressure (stock load range E's are good for 80 psi)
Tall, soft tires aired up to a max of 65psi just aren't going to be wonderful for handling with a large top-heavy slide-in camper. Hopefully the tires will work OK for you, I just don't want someone to spend major $'s on new tires and be disappointed because the load rating was acceptable.
Cheers,
Dave
