I know there are a million fuel pressure gauge questions on here but I'm a little confused after researching the old threads. I have a a 12 valve but I introduced two friends at work to the world of the dodge diesel and this site. One truck is a 2002 non HO with 120,000 miles bought off his brother-in-law who had the injector pump go out once when it was new and no problems ever since. It seems to have a fuel pump in the tank. (you can hear it when you turn the key on). The other truck is an 01 HO. It has had several lift pump and injector pumps replaced by previous owner. The other day doing 70mph it started to cut out, changed the filter and now it runs good. So we're a little worried about having low fuel pressure now.
My question is:
1) Can we just run a gauge off the banjo fitting? If so will we need a snubber to reduce pulsation for a mechanical gauge?
2) If it's got an electric pump will it pulsate like a mechanical pump?
3) does it matter if we use an electric sending unit or mechanical?
4) any difference in installing a gauge on these trucks since one is mechanical pump HO and the other is electric pump non HO?
We just want to keep it simple, no mods later down the road, no need for a control box just want simplest fuel pressure gauge. Was looking at the ones in geno's catalog but they didn't say anything about pulsation. Thanks for the help We appreciate it. This site has literally saved me thousands of dollars and given me enough knowledge to make my truck last for hundreds of thousands of miles.
My question is:
