New to me 2003 CTD
Hard starting Fuel heat sensor or element problem I think
Shifting Reccomendations
I recently moved up from a '95 to a 2003 CTD std cab truck that is a BASIC model ie. no power windows nor door locks. Are these items relatively easy to install if obtainable? Thanks. Bill Zehner
How much do you want to spend, and I think its possible but don't recommend it. If its in your budget buy the new 07 CTD 6. 7 with what you want
I think what I would do is find a wreck in a junkyard. You will probably need door panels and armrests to accomodate the switches. As you strip that stuff off you can see how it is attatched, therefore how you should re-install on your truck. It can't be very difficult. Running all the wires will be the biggest PIA.
My dually lacks all the power stuff too. The only power accessory I wish it had was power mirrors. I like the manual windows and locks, especially in a std cab.
