Picked up a 1994 2500 with 169K on it today and have a few questions. I did search and found a few answers but I have some more questions.
1. I'm going to install a DD mag hytec pan and put the stock trans temp sensor in the pan and the sender for my gauge in the hot line. Will this allow lockup and O/D operation to work normally or do I need to install the resistor?
2. The truck has 2 gauges installed a 30psi boost and pyro. The pyro is installed post turbo and wont get any higher than 850, while max boost is 17-18psi. To me the EGT's seem a little high for post turbo and only that much boost. This is a WH1C turbo. I havent looked too close yet but is there a way to block off the wastegate on this turbo to produe more boost?
3. I'm going to get the KDP done, change all the fluids and filters, install new boost, pyro, trans temp gauges, remove the silencer ring, throw in a BHAF and straight pipe it. Anything else I'm missing? I'm happy with its performance so no real bombs for now, but is there anything else I should check over or possibly replace?
thanks
Zach.
thanks
Zach.
