The stock fuel filter canister mounted lift pump is weak, better off replacing it with an aftermarket system. Glacier Diesel Power has several replacements, and Richard the owner is very helpful in helping you choose what's right for you.
As far as injector failure, the 04. 5+ years had more than the 03/04 yrs. The biggest problem is lack of proper filtration, the stock filter is 10 microns, the new replacement is 7 microns, and Bosch recommends 5 microns. Again Richard could help you with a 2 micron setup.
Other than that, enjoy your new truck. If you look on the driver's side valve cover, you will be able to tell which 03 you have. 230hp, 250hp, 305hp. All are excellent, and a Smarty will level the playing field.
Jess
