new track bar with 2" lift ??
step shild
Dual EGT gauges
So I've spent the last hour reading about the different track bars available, and I have one last question.
I am about to install new 2" springs in front, and from everything that I've read, this will move the axle to the drivers side a small amount.
Is an adjustable length track (DT) bar the only way to fix this ?
I have read that some of the track bars are adjustable, but only to take out the play that occurs as the joints wear out. I am assuming this is not the same adjustability as the DT has.
I also read that there is at least one track bar that is longer than stock by about 3/4", was this designed for the 2" lift ?
I don't mind spending the $250 on the DT, but with all of the fun mods I have in mind, I do have to pace myself :(
Thanks,
Damon
damon,
When I put on my 2 inch lift, I went to a steel house and found a piece of steel tubing with . 33 inch wall that was a snug fit over the track bar. I cut the bar and welded a splice on it lengthening it the right amount. I can't remember how much I lengthened it since that was about 5 years ago. My memory is good, it's just short.
I also installed a Luke's Link and couldn't be happier with the track bar performance since.
