I had the auto transmission rebuilt in my 01 CTD a couple weeks ago. They upgraded the valve body, put in a billet single disk TC and a rebuild on the rest.
When I picked up the truck it was ... WOW!!! It was like a different truck. The power increase and lower boost numbers were very noticable. The truck shifted quicker too!!! The most I pulled was my Jon boat and it only weighs maybe 2000 lbs. Truck did Great!!!
This past Thursday I hooked up my fiver for a trip to Columbia Missouri. (120 miles) My fiver is very heavy... . 18,000+ lbs. The truck pulled much better with the rebuild, but two different times starting out from a stop light the truck seemed to shift very quickly back and forth from 1st to 2nd. It was very violent in the jerkiness. Then once on interstate 70 west bound while I was cruising about 60-65 mph I thought I noticed a slight slip when I accelerated. The tach climbed about 100 rpm if I tried to accelerated, so I slowed down and took the transmission out of OD. I didn't want to run the engine too hard as far as high RPM's so I would only shift out of OD on completely flat ground, then downshift at any hills.
Okay,,,, made it to Columbia without any other hitches. We came back on Sunday... while on Hwy 70 I could not get the transmission to slip in OD no matter what I did nor did the truck shift funny from a dead stop. All seems great!!
On the way back home there is a very steep hill, it is about 1000' long and has sharp corners in it so no way to get a run at it. As I was going up the hill the transmission downshifted as expected. I was only able to run about 15 MPH up the steepest part. I was concerned if the truck was going to pull the hill, the RPM's where over 2500 and I noticed the engine temp climbing very very fast. The truck did pull it, but my water temp in the truck was near redline (240 I think), I hurried through the stop sign at the top of the hill and started down the other side to cool the truck off. It cooled off pretty quick. The truck never gave any other trouble or funny shifts the rest of the way home.
My questions are this:
1: Could the TC have slipped because it was new and now it is OK?
2: Is it normal for the truck to have heated up that fast and high in temp in such a short distance?
3: Was the heating up caused by the TC slipping?
4: If I need to take it back to the shop that rebuilt it, can they tell what is wrong without a heavy load behind the truck?
Notes: I am running a SuperChip on the Tow safe mode.
Thanks for any help... . sorry it's so long but I am trying to describe the conditions best I can.
They guy told me the name of the TC manufacturer but I cannot remember it, it was 2 names.
Brian K
Brian K
